| | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2010 Posts: 150 | Hello all, I'm thinking of purchasing a 54 3600 dually that has a flat bed on it. If i put single tires on back would a standard 54 bed bolt right on without much trouble? | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I didn't know they made 3/4 tons with a dually rear. Are you sure it's not a 1 ton? If's it's a 3600 you can swap out the duallys.
~Jim
| | | | | Joined: Feb 2000 Posts: 120 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 120 | I am thinking Yes, but it would have to be a "standard 3600" pick-up bed that is 90" long.
3100 bed is 78" & 3800 bed is 108"...
The 3600 dually is 3608 & 3609 with dual 16" tires
Wheelbase: 3100=116" 3600=125" 3800=137"
I'm sure some of the other guy's will have more, soon
Good Luck! 1954 44001954 3800Jim D. '41 Chevy 1-Ton Pickup/dump...292" 4-speed w/Ranger OD ... Newest Truck '54 Chevy 3800 Dump........New Truck! '54 Chevy 4400 flatbed/dump, Gone to my brother-in-law '13 GMC 1500 daily driver ... 5.3 6-speed auto just turned 13k miles '01 Chevy 2500hd, might be my new daily driver ... 6.0 / 4L80-E
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | If that is true then you will be able to junk the dually and replace it with a standard rear of some variety. Of course you could just pull off a tire from each side.
~Jim
| | | | | Joined: Nov 2010 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2010 Posts: 150 | | | |
