2 members (2-Ton, 1 invisible),
108
Mod | | | Forums66 Topics128,034 Posts1,055,546 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 100 | Hi,
I'm having difficulty finding anyone who can supply a key for my 1941 pickup. I'ce removed the handle and have the number 8785 on the side.
Anyone know where I can get a key for this lock?
For those who believe, no proof is necessary. For those who don't believe, no proof is possible. 41 Chevy | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | no locksmith nearby? maybe check with this one in England Bill | | | | | Joined: Jan 2008 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 100 | I've taken the lock - and handle - to a couple of locksmiths but they don't seem to know what to do if they're not just copying a key!
I'll PM Nick.
For those who believe, no proof is necessary. For those who don't believe, no proof is possible. 41 Chevy | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | Go to one of your local vehicle swap meets.There is usually a locksmith there with older key blanks who can help you out. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | The blanks you need are B10 and B11.
| | | | | Joined: Jan 2008 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 100 | Glamis Car show is in 3 weeks so if Nick can't help I'll try at the show.
Thanks D
For those who believe, no proof is necessary. For those who don't believe, no proof is possible. 41 Chevy | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I've taken the lock - and handle - to a couple of locksmiths but they don't seem to know what to do if they're not just copying a key! Not much of a locksmith if all they can do is run a machine. The cut for 8785 is 353432. Have them cut it on a B10 blank. | | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Dalbuie:
If nothing else works send me the number stamped on the inside end of the chrome handle and I get you a key at a same local lock smith that made mine for me. Then mail it to you | | | | | Joined: Aug 2010 Posts: 127 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 127 | look on Ebay I saw someone who will cut a NOS GM key blank to what ever GM code you give them. | | |
