4 members (delwrench, Southerntruck, cmayna, dt235sd), 123 guests, and 3 robots.
Topics128,142
Posts1,056,490
Members48,442
I noticed that my 55 2nd series (stock) is all of a sudden leaking all the differential fluid out the pinion seal. I wanted to first replace the vent tube as I think it may be clogged from when the rear end was sandblasted. Does anyone know how to remove/replace this? I don't know if it screws off or pops off. thanks.
It's a work in progress! Started August 08. gotta finish before the baby comes August 20th!
https://picasaweb.google.com/tomnmindy/Truck?authkey=Gv1sRgCOj0gsiF6ZCDKQ&feat=directlink
never mind, I saw it unscrews (albeit it's hard to get it off). Sure enough, it was clogged up with sand. Once I blew it out, no more leak!
