| | | Forums66 Topics128,134 Posts1,056,402 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 201 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 201 | Got a 48 Chevy Suburban with the Clam Shell doors, on the lift gate im trying to take out the handle and i cant get it out. Any tricks or special way to do this??? Does the handle have to be turned to take it out??? | | | | | Joined: Jan 2002 Posts: 237 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 237 | My 1946 tailgate had a keyed "T" handle held in by a bezel on the outside with a screw on each side.
Once I removed the bezel the handle pulled right out. | | | | | Joined: Sep 2004 Posts: 201 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 201 | my t handle does not have a screw on each side. However there is a nut on the back behind the cover that the handle goes to. I took the nut off but the handle wont come out. I think the handle is locked so i cant turn it very good and i wonder if the handle needs to twist to take out. | | |
