3 members (cmayna, TUTS 59, 1 invisible), 146 guests, and 3 robots.
Topics128,070
Posts1,055,896
Members48,428
#755722 06/19/2011 3:46 AM
1953 spedo just needed a needle.trying to get the old on off I broke the drive stem.So folks where can I buy a new spedo drive mechanism without buyiny the entire unit.OR can the stem be soldered and if so do you think it will be a problem getting the new needle seated to 0 or the right location.Any way help on this AND getting the mileage set to 0 with this new engine etc.Thanks Gang
OLTrucks
Unregistered
OLTrucks
Unregistered
Let me dig around in my speedo parts box I might have one with a good stem that I can let go of.
Does anyone know of a source for the rubber o ring -seals that go under the bezel at the glass of the instrument cluster and spedo for the 47 -53 ad units-Thanks Sid stephenson
Thank you and let me know.Sid--Do you have a source for the rubber o ring seals under the glass ?
OLTrucks
Unregistered
OLTrucks
Unregistered
I have some of those handy I know. I had rebuilt guages for a few years for one of the retailers
yes it is and I thank you --will order tonight .Appreciate info.
I have all the parts and never put the speedometer back together. I bought a few over the years. I have a odemeter dial with all new decals, the base, a new needle, and the guts, bezel, gaskets, and the glass. I have a few extra other parts here and there also. Let me know if you need it Sid, the hardest part to find is the odometer.
Yes sir I do need all these items .I'm trying to re do 3 speedometers and clusters.Tell me what else is here and there also please and what I owe you and a mailing address and I'll get you paid.Sid
The odometer cost me somewhere around 80 or 90 dollars, I can group all my speedometer parts together for 200, shipping should go in a "if it fits it ships" box for 20 dollars. I can take a picture of everything together so you can make a decision and not be blindsided. Let me know if you are interested. Thanks John
Person-to-person buying/selling/bartering can and should take place by way of private messaging.
