| | | Forums66 Topics128,010 Posts1,055,299 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2011 Posts: 63 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 63 | While I was working on my '53 truck I noticed that one of the transmission's linkage arms springs (I'm assuming that's what they are called) is missing. I haven't had any problems while shifting gears, but I would like to find a replacement. Unfortunately neither our local parts stores nor the hardware stores have one. I was wondering if any of you guys know where I could find one. Any assistance will be greatly appreciated. Charlie. Spring
| | | | | Joined: May 2005 Posts: 487 'Bolter | | 'Bolter Joined: May 2005 Posts: 487 | You should be able to find a suitable replacement at Lowes, Home Depot, or Northern Tool. What is it, 3/8 ID?
regards, Leon | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | I had the same deal. Found one close to what I needed at Sears Hardware and cut it to length size.
Drew
| | | | | Joined: Jun 2011 Posts: 63 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 63 | 5/16, but a 3/8 would do. I will check again at the Home Depot.
Thanks, Leon.
Charlie. | | | | | Joined: Jun 2011 Posts: 63 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 63 | Drew:
Maybe my problem is that I've been looking for an exact match. I'll see if I can find one that I can cut to size.
Thanks! | | | | | Joined: May 2005 Posts: 487 'Bolter | | 'Bolter Joined: May 2005 Posts: 487 | How about Home Depot #16087 ? Also, if you find one that's the right diameter, but its an extension spring rather than a compression spring -- just stretch it. regards, Leon | | | | | Joined: Jun 2011 Posts: 63 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 63 | Leon:
I finally found one at another hardware store that I forgot we had here in Brownwood. All I had to do is cut to length size. Thanks!
Charlie. | | |
