5 members (TooMany2count, fonz8261, Peggy M, TexasJim50, Chip O), 65 guests, and 1 robot.
Topics128,032
Posts1,055,528
Members48,425
#754978 06/16/2011 5:39 AM
I got a Delco Remy Alternator at a boot sale.Itis marked 1101140 and N209D.
An extended Internet search for a wiring diagram did not bring me any results.
It has a connector with 4 pins. The connector is marked PL FS as shown in picture:
http://s875.photobucket.com/albums/ab317/Jianis/Delco%20Remy/?action=view&current=-DL-.jpg
On a bench test I found out that if I connect the second pin (corresponding to the L of the PL marking) to the battery positive pole the alternator starts producing 14.7 volt.
Does anyone know what the function of the other pins is?
Thank you
Jianis
Jianis #754989 06/16/2011 6:42 AM
Jianis;
Here is a link that explains the pin outs and even mentions conversion plugs etc. Scroll down the page about 1/2 way and you'll see the PLFS wiring stuff. Good luck.
SimS
http://www.extreme4wheelin.com/tech/alternators/tech.htm
SimS #755064 06/16/2011 5:13 PM
SimS
That is the right link for my application.Now i have all the basic information that I need.
Thank you
Jianis
