1 members (klhansen),
92
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,741 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 143 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 143 | Finishing up the frame off on my '50 3100. I swapped the 216 for a 235 from a 1955 Chevy Belair with 136 hp and originally a powerglide. Pretty much followed the 216 part reuse recommendations in the Tech Tips. I rebuilt the engine and test ran it sitting in the frame. I finally have the body back together and went to drop in the radiator but the fan is too close to allow assembly. I'm trying to figure out what the problem is. I just read a previous post that stated there are 7 different fan blades for the 235. Since all I know is that the fan I have fits on the engine I'm thinking I might have a fan that is the wrong size. Can anyone tell me what the clearance between the fan and radiator is? I keep reading some pretty tight measurements. Any suggestions? Thanks.
It never costs more to ask and it never costs more to think big.
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy jss1956, there are two basic ways to deal with the too long waterpump problem, buy a special short waterpump that fits your engine, or buy an adapter and use an early 235 or 216 waterpump, the adapter method puts the fan in the correct place on the radiator up and down wise, hope that helps. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy jss1956, there are two basic ways to deal with the too long waterpump problem, buy a special short waterpump that fits your engine, or buy an adapter and use an early 235 or 216 waterpump, the adapter method puts the fan in the correct place on the radiator up and down wise, hope that helps. | | | | | Joined: Aug 2004 Posts: 143 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 143 | I failed to mention that I have the short water pump already installed. So I'm covered there.
