6 members (Hotrod Lincoln, 48ed56pam, Ponchogl, lumbersawyer, MickeyP, Bill Hanlon), 136 guests, and 2 robots.
Topics128,081
Posts1,056,073
Members48,434
#754240 06/13/2011 2:59 PM
rod came off, gate locked closed. any tips? HELP!
On the inside of the lower end gate, are a few small access panels. By removing them, you can access the inside of the gate and the latch mechanisms. You will be able to manually manipulate them, in order to release the latch & open the gate.
even easier! put a hacksaw blade into the latch on the door at an angle and push while holding gate closed a little, popped right open!
