Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (TrknGMC, Ed Atkisson, 1 invisible), 58 guests, and 3 robots.
Topics128,010
Posts1,055,299
Members48,419
#754544 06/14/2011 5:21 PM
I was just wondering whether to put a/c on my 59' GMC and I was wondering if it would take away from the horse power?
Daniel_Clark #754552 06/14/2011 6:05 PM
6 or 8 cylinders? With the compressor running you will see a difference. More with a smaller engine than with a bigger engine. I personally would do it and have done it for my ’65 and ’53 and it’s on the list for the ’66 – the parts are already ordered.
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
johntsmith #754581 06/14/2011 7:58 PM
if you were in my town today, the answer is yes..
I heard someone say that an air conditioner will cost you about
10 hp...not sure if that is true or not......today I would take that loss
Redryder pix
My Hotrod
joker #754587 06/14/2011 8:47 PM
Daniel,
Your in GA. It's hot this time of year. Who cars about the HP loss. If I had the means I'd have it in my truck too.
I'm just sayin.
Chris
Proud Southern Stovebolter
Share the past for our future:)
1964 C10
http://s679.photobucket.com/albums/vv153/chrisgardner07/CGG_64C10/
CGG_64C10 #754591 06/14/2011 8:51 PM
My A/C is gettin filled on Friday. Today is 95 degrees.
Daniel_Clark #754601 06/14/2011 9:21 PM
My 37 just went into the A/C shop for plumbing. Blairsville, GA
APV60 #754622 06/14/2011 11:37 PM
My 54 needs my a/c repaired also. Three weeks of over 90 degrees and still using my wing windows for a/c.
Disciple
Ted W #754630 06/15/2011 12:22 AM
My '40 has a cowl vent, crank out windshield, and open windows. Nice and cool......'till ya STOP!....... wink
1940 Chevy 1/2 ton pickup "KC"
A day without sunshine is like, well, ..... dark!
40casey #754645 06/15/2011 1:03 AM
The "horsepower loss" story is pretty much of a myth, unless you're running a really small engine. Even with a very heavy heat load and high head pressure, it shouldn't take more than 1 or 2 horsepower to cool an area the size of a truck cab. A 5 HP compressor cools my entire house, all 3,000 square feet of it!
Hotrod Lincoln #754767 06/15/2011 2:10 PM
My air was charged yesterday. Looking forward to wearing a navy peacoat down the highway soon.
~Jim
BIG CHEVY 3600 #754769 06/15/2011 2:23 PM
Daniel,
When drag racing, turn off A/C. Put a good coat of wax on your vehicle to cut down on wind resistance. Also, there's 2-50 A/C that doesn't take much away from performance. That's two windows down, 50 miles per hour.
orchidskip #754815 06/15/2011 6:57 PM
I have it my 54 but only turn it on to make sure the compressor get lubed. we have 95 degree days but with the rear slider and cowl vent i don't need it. it is cooler than my Pt when i open it up. the car seems to hold heat a lot longer.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Hotrod Lincoln #754884 06/15/2011 11:24 PM
Riding in the Passing Lane
HRL probably knows more about this then I do. He has run them on Dynos & such. The newer cars have variable disp. compressers but the old A-6 & comps. from a few years ago pulled a lot of power from an engine. Ive heard as much as 25 HP. I know you can sure feel the difference & that belt better be really tight or it will squeal.
1972 Chevy c10 Cheyenne Super
Wrenchbender Ret. #754889 06/15/2011 11:37 PM
I think he was joking with me
Redryder pix
My Hotrod
joker #754922 06/16/2011 2:35 AM
the torque draw of the compressor will be dependent on the compressor size, line size, system size, refrigerant used, temperature deltas, etc. the horsepower will be dependent on the torque required by the compressor, the clutch pulley size, the driver pulley size, and the engine RPM.
everything that is driven off the engine, or electrically draws power. however electrical draws are buffered by the battery to some extent.
between 1 and 5 hp is a rough rule of thumb, however as many people indicated - if you want AC, who cares how much hp is drawn.
Scott Danforth #754940 06/16/2011 3:55 AM
I live in the South and vote for AC and I'm ok with it taking a few of my ponies. I'll probably get in more trouble from the electric cutouts on the exhaust than a heavy foot. LOL.
