1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#754403 06/14/2011 2:37 AM
Hello everybody,
Has anyone out there in old truck land ever painted a truck with a brush or roller? If so which did you get better results? Did you just walk out and start painting or did you do any kid of prep work first. What kind of paint did you use. I am thinking of doing the deed on my old truck and just was wondering how others may of went about it.
thanks,
Harrydale
Harry - lots of folks use a brush/roller to do a thrifty paint job, some use tractor enamel from a farm supply, some use Rustoleum, some use house paint .... I've done a big bus with a roller for large areas and a brush around the edges or where the roller doesn't reach - looky here ... I used Zero Rust, which worked well if you don't mind the mat finish, although they have a clear coat used for UV protection that gives a smoother finish
best to do a proper job of sanding including taking it to bare metal where necessary - the final job will reflect how much prep you put into, if you're trying to avoid any sanding at all might as well skip the paint, won't last long
i took a angle grinder with a wire wheel and buzzed the whole truck including the box. i experimented in places with rusto hunter green. it looked ok. i ended up using "XO RUST" hunter green its better than rustoluem so thre guy said at the paint store. its going on four years now and its holding up well. the only place where its coming off is from using the dump as a dump from wear and tear. every winter when its in the garage getting a pre physical for the inspection garage i give it a wash and go over it with a coating of meguires quick wax and it brings the sheen/shine right back out. whats nice with the XO RUST is that it dries to touch(light handling) in about two hours with the right air unlike forever with rusto.
my webshots shows before and after pics of the dump. the sheen isnt as great as the parade set up but then it was just painted and garage kept until i got the 40.
