| | | Forums66 Topics128,089 Posts1,056,437 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2011 Posts: 91 Wrench Fetcher | | Wrench Fetcher Joined: May 2011 Posts: 91 | hey, couldn't salvage my 1941 chevy 235 straight six due to rust pitting on the #1 cylinder wall and corresponding block deck area. found a 1955 235 full oil pressure engine for $250. supposedly ran when it came out to be replaced by a V8. i also found an engine stand originally purchased from napa now selling for $65.00 locally on craigs list. will any engine stand work? if not, what do i look for? EVERYTHING is new to me.  thanx, marc | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | Get a sturdy one with 4 legs. These engines are HEAVY so make sure you have a stand that will suport it.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: May 2011 Posts: 91 Wrench Fetcher | | Wrench Fetcher Joined: May 2011 Posts: 91 | i had heard somewhere that the bolt pattern was different. are engine stands pretty much universal? thanx | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Recent thread on engine stand. The bolt/hanger arrangement on various engine stands are quite possibly different. Some people have reported making a mounting plate/adapter to get their stand to attach to their engine. I have used several brands/styles of engine stands and have been able to find a way to get all of them to attach to a 216/235/261 blocks. In some cases, I have had to attach arms in the opposite orientation, bolting the stand-end of two arms to the block and bolting the block-end of those arms to the stand. If you get stuck finding a way to bolt up your stand, post here and I'll take a few photos of the bolt-on arrangement I am using on these stands. | | | | | Joined: May 2011 Posts: 91 Wrench Fetcher | | Wrench Fetcher Joined: May 2011 Posts: 91 | hey tim, i appreciate it. i'm waiting for a call from the guy now. i'm gonna go ahead and get it. if i run into some mounting problems i'll take a pic and let you know. marc | | | | | Joined: Sep 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 461 | Three or four leg is fine.....some guys talk about flipping a three but i have never done that with my rebuild. Like tim said, have to flip a couple of arms around, be careful. Remember it is a stand and hopefully you will be installing the engine quickly rather than rolling it around the shop on display  Hank | | |
