3 members (baldeagle, Mike B, Hotrod Lincoln), 83 guests, and 1 robot.
Topics128,026
Posts1,055,409
Members48,422
#754121 06/13/2011 1:41 AM
My steering/rag joint has sheered off and busted, what suggestions for this? Seems to me that on the steering shaft part of the joint is not removable. Any replacement parts available or just put some bolts in it and drive?
1966 GMC
Riding in the Passing Lane
Repair kits are available from any parts store. New ones are available but are expensive.
1972 Chevy c10 Cheyenne Super
Thanks guys, i ended up cutting the original posts holding it together and replacing with bolts, works fine.
1966 GMC
That rag joint is designed to relieve pressure off the top bearing of the gear box. You should replace the joint and your gearbox will thank you by giving you longer years without leaking.
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
