Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
7 members (DavidBraley, Otto Skorzeny, J Lucas, 66flea, Rosco, 55shaker, 1 invisible), 122 guests, and 5 robots.
Topics128,283
Posts1,058,504
Members48,490
U
U Offline
Hey guys, I have searched for days trying to find rubber to convert my sliders to fixed side glass. Any body know where to get the rubber/glass? Thanks
1969 Camaro SS #s Matching
1955 Suburban Carryall (Cummins powered in the works)
2002 Camaro SS LE#1320
2011 RAM 2500 6.7 CTD Laramie Longhorn (H&S Mini Maxx and all the EPA crap removed smile
unclebuck if you are going to have a "Glass House" install the windows you may want to talk with them first. Most of the guys that do this type of work have a favorite supplier that they use. I bought some through Steele and the installer said thanks but I like "X". IF you are doing it yourself giv Steel a call and walk them through year mdel etc. and they can suggest a solution. Since it is not an original it will not be a one piece molding but will require cutting to fit from a roll and gluing the ends. Good luck.
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison
Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
