| | | Forums66 Topics128,148 Posts1,056,810 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 14 New Guy | | New Guy Joined: Oct 2010 Posts: 14 | Hey guys, I have searched for days trying to find rubber to convert my sliders to fixed side glass. Any body know where to get the rubber/glass? Thanks
1969 Camaro SS #s Matching 1955 Suburban Carryall (Cummins powered in the works) 2002 Camaro SS LE#1320 2011 RAM 2500 6.7 CTD Laramie Longhorn (H&S Mini Maxx and all the EPA crap removed | | | | | Joined: Jul 2010 Posts: 90 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 90 | | | | | | Joined: Nov 2001 Posts: 438 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 438 | unclebuck if you are going to have a "Glass House" install the windows you may want to talk with them first. Most of the guys that do this type of work have a favorite supplier that they use. I bought some through Steele and the installer said thanks but I like "X". IF you are doing it yourself giv Steel a call and walk them through year mdel etc. and they can suggest a solution. Since it is not an original it will not be a one piece molding but will require cutting to fit from a roll and gluing the ends. Good luck.
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
