| | | Forums66 Topics128,014 Posts1,055,324 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#75394 03/25/2007 3:47 AM | Joined: Apr 2006 Posts: 171 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 171 | Sorry for a potentially stupid question, but when you are measuring the float level (say, on a Rochester B), are you supposed to measure from the top of the bowl with the gasket on or off? If you follow the instructions it seems like the gasket should be on, but that seemed suspicious to me. Carb experts please advise!!! | | |
#75395 03/25/2007 4:37 AM | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy gjberche, in my Motors manual it says measure from gasket surface, and the accompanying drawing appears to show the gasket in place for both the float level and float drop settings, hope that helps. | | |
#75396 03/25/2007 4:45 AM | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | I did this today for the first time. It shows in my chevy maintenance manual: the gasket remains on and you measure 1.75" drop. Most stovebolt web posts indicate they like it a little longer to keep the carb from leaking gas around the gasket. | | |
#75397 03/25/2007 5:50 AM | Joined: Apr 2006 Posts: 171 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 171 | Thanks guys! I measured with the gasket on, so I'm glad that is the correct way to do it. | | |
#75398 03/27/2007 1:33 PM | Joined: Feb 2006 Posts: 395 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 395 | If you have a kit it should give spects in the kit,,if in dought set with gskt on as that will lower fuel level in carb the thickness of the gskt and that will cause the engine to run a touch leaner and in most cases that is good,,but in some cases if the engine is on the lean edge it gould cause you to use too much throttle at crusing speed thus opening the power sys to early and fuel milage giong down..OH God I,m rambling agin sorry...doc | | |
#75399 03/28/2007 2:40 AM | Joined: Nov 2002 Posts: 2,763 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,763 | Got to interject a point here: NEVER make the assumption that the gasket should be in place, or not in place. Different carburetor manufacturers used different methods. ALWAYS read the shop manual for the vehicle, and follow the instructions in the shop manual, NOT IN AN AFTERMARKET KIT!
As a point of interest (maybe to some of you), the following methods have been used to set the float, by various carb manufacturers specifications:
A) with the gasket in place B) with the gasket removed C) when the fuel dribbles out the fuel inspection hole, the setting is correct D) set the FUEL LEVEL at <dimension> with <amount> of pressure on the fuel valve E) don't bother it, if you buy a new float and a new float valve, and install the float valve with the proper torque, the float is perfectly set.
I personally like "E", it helps sales! :big grin:
A further point: older fragile (read expensive to replace) floats may be adjusted WITHOUT bending by increasing or decreasing the thickness of the gasket used under the fuel valve seat.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | |
