2 members (Hush, Forty9), 90 guests, and 1 robot.
Topics128,050
Posts1,055,643
#75390 03/25/2007 1:08 AM
Junior Member
Junior Member
Can anyone help me identy what year and model of truck this transmission came from?
It is a 4 speed with the shifter entering at the top. Is has no cross member mounting bracket. Does not really have a tail case and uses a U-joint yoke on the output shaft. Gear shift pattern is the stardard "H" with reverse toward the driver and back to the rear.
Top cover has the numbers GM 3, 591588.
Numbers on the side of the case are:
B2381, 14 GM T, 3787239
It is short but looks pretty heavy duty.
#75391 03/25/2007 1:58 AM
Sounds like the old Muncie/GM SM420 granny gear 4-speed that was used in the 40's and 50's. Got a picture?
#75392 03/25/2007 3:20 AM
Had another thought on this: do a Google search for SM420, you'll see lots of articles, pictures, date codes, etc. Found out the SM420 was used on Chev trucks from '47 thru '67.
#75393 03/25/2007 3:23 AM
Junior Member
Junior Member
Yep, just did that and that is exactly what it it.
Super, thanks!
