1 members (Gray_Ghost), 83 guests, and 2 robots.
Topics128,080
Posts1,055,956
Members48,430
#753696 06/11/2011 2:43 AM
I
I Offline
Oringinally posted in "Doors" but still need help. I need help in finding the following part. It is the guide that holds the door window channel on the back end of the door. Please see picture. I think I've seen them on a vendors site but can find now. One was broken when removed. Are there any venders that read Stovebolt
Thank you for your help, Scott
http://i740.photobucket.com/albums/xx49/49chevyia/IMG_1457.jpg
A freind of mine with a 50 was looking for that same part and He ended up getting a used set from E-Bay I don't think anyone makes em they make the ones for 51 and newer We could not understand why they don't make the older ones.Put in ad in parts wanted there are guys that are parting out trucks and you could get a set from there.
Good luck
Pete
try bow tie bits in whitchata kansas....they sell some used parts......dave
1949 Chevrolet 3100
"When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
Chevys of the 40s also carry these. That's where I got mine.
~Jim
I
I Offline
Found them at Chevy of the 40s. THX for the help. Always good advice/help at the Stovebolt. Can't wait to get the windows in.
Dang ia49, that's one perfect truck.
~Jim
You guys go a number for them? I've been looking thru their catalog for an hour and can't find them listed under any door or window discription.
DG
Denny G
Sandwich, IL
I
I Offline
They are called: "Chevrolet Right door lower glass run post front"
Part #s: 3685370 for the right and 3685369 for the left.
Each kit is $25 plus shipping. therefor $50 plus $28 shipping for both sides. High cost but I haven't found them anywhere else.
Thanks. Doesn't look like they are supplying the double J-nut that goes on the bottom. Also I don't see the slots for the run channel clips.
Whats with $28 shipping???? I'd question that, UPS, USPS or Fed-X shouldn't be more than ten or twelve bucks for somthing that size. It's just an 18" sheet metal channel that probably doesn't weigh more than a half pound, hardware included.
DG
Denny G
Sandwich, IL
