1 members (Dusty53),
174
Mod | | | Forums66 Topics128,101 Posts1,056,180 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 81 | Hi all. Been trying to get my truck to run better, tuning it etc. I have noticed that the linkage is jamming up against the intake causing the idle to remain to high. I was just wondering if any one has photos of the their dual carb linkage from the pedal all the way to the carbs, or even links where I can buy a new linkage. No sure if my linkage was homemade or aftermarket. Was on the engine when I purchased it 17 years ago.
1950 Chevy 3100 Blog w/Pics - http://txchevy50.blogspot.com/Goal: Clean, Rebuild, Paint, & Drive on a budget. Major restore of components will be done over time. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | I couldn't find a pic on your web site of your engine to see what your linkage looks like. Here is a link to see a pre packaged Offy set. www.stoveboltengineco.com
Drew
| | | | | Joined: Aug 2010 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 81 | I will take a pic of mine tonight. I was able to adjust everything so it no longer rubs yesterday, however the front carb seems to be the source of my idle problems. It would appear that the return spring is not strong enough, to return the throttle fully. Its like 1/8 or less of a inch off.
1950 Chevy 3100 Blog w/Pics - http://txchevy50.blogspot.com/Goal: Clean, Rebuild, Paint, & Drive on a budget. Major restore of components will be done over time. | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | I have some decent photos listed on my Picturetrail site below. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | TXChevy50, It looks like you have dual 1-barrel (original style) Rochesters. Dave's linkage looks like the set that Tom Langdon sells for Carter-Weber (and maybe Holley-Weber). Here is a single carb linkage but he also sells a dual carb linkage: C-W & H-W linkage However, Tom Langdon also sells the Rochester set also (a set sold by several vendors): Rochester linkage | | | | | Joined: Aug 2010 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 81 | Hey guys, thanks for the replies. I uploaded some pics of my setup. Click my link to see them. Does it make sense that the return spring on the front carb is not strong enough to reset it all the way everytime? Its intermittent, but when it is idling to high, that carb is usually about 1/8" off from fully closed.
1950 Chevy 3100 Blog w/Pics - http://txchevy50.blogspot.com/Goal: Clean, Rebuild, Paint, & Drive on a budget. Major restore of components will be done over time. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | That stock Offy linkage makes it a pain I think to equalize the carbs. In my experience it is too sloopy, especially when you have two different style carbs where the accelerator arms don't line up exactly. Plus the bolt connections slip. I would spend some time adjusting the linkage and maybe use a system like has been shown in the posts to you. The other issue I see is that the return spring for your accelerator arm is supposed to attach to a clip mounted on an oil pan blot. That gives it vertical action. Maybe that spring is weak too. Just my 2 cents.
Drew
| | | | | Joined: Aug 2010 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 81 | Drew,
I noticed that as well. I thought it didn't look right, but the part the upward arm attaches too/rotates, is different than the stock one on my old engine. This came out of a 1955 BelAir. The Pedal link to this is not right either. Been thinking about just going back to a 1 carb setup, like a Webber 2 barrel on that site above. I just need a whole linkage replacement from the pedal to carbs and the old manifold I have is supper rusted up inside and out from sitting in the weather for the last 1 years.
1950 Chevy 3100 Blog w/Pics - http://txchevy50.blogspot.com/Goal: Clean, Rebuild, Paint, & Drive on a budget. Major restore of components will be done over time. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | TXChevy50,
If you are going for a single 2-barrel "Weber" carb from Langdon's, the Holley-Weber might be OK but the Carter-Weber would be too small.
| | | | | Joined: Aug 2010 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 81 | TXChevy50,
If you are going for a single 2-barrel "Weber" carb from Langdon's, the Holley-Weber might be OK but the Carter-Weber would be too small. I know I don't want to spend more money than I have to, but I want something simple and easy to work on. I am just not sure if its old springs, or a bad linkage design, or just going to a two barrel carb. I drive this truck alot, and need it dependable.
1950 Chevy 3100 Blog w/Pics - http://txchevy50.blogspot.com/Goal: Clean, Rebuild, Paint, & Drive on a budget. Major restore of components will be done over time. | | | | | Joined: Aug 2010 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 81 | I decided to move on to something better. After talking with Tom Langdon( http://stoveboltengineco.com/), he suggested I upgrade to the Carter/Webber 2bl carbs & upgrade to a HEI ignition. So parts are ordered. Should be here in a few days. Hope that this will get my truck to a solid running/driving state.
1950 Chevy 3100 Blog w/Pics - http://txchevy50.blogspot.com/Goal: Clean, Rebuild, Paint, & Drive on a budget. Major restore of components will be done over time. | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Once, and if, you get them synchronized I think you'll be happy with them. I wouldn't do it again but they do look cool and work pretty well albeit hardly perfect. If there is a next time it will be a single 2bbl or small Holley 4bbl. | | | | | Joined: Aug 2010 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 81 | Yeah, I was pretty set on going to a single carb, but langston basically said that since I already had the dual intake, purchasing the dual carbs with his linkage system, the synchronizing shouldn't be a issue. Will see soon.
1950 Chevy 3100 Blog w/Pics - http://txchevy50.blogspot.com/Goal: Clean, Rebuild, Paint, & Drive on a budget. Major restore of components will be done over time. | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | Tom is suppose to say that, ...lol
by the way, nice truck Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Aug 2010 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 81 | Haha yeah, I know there was some sales tactics there, but I didn't want to mess with breaking manifold bolts either, since this offy has been on here for 16 years..
so hoping it all goes well, will know soonq
