3 members (Bill Hanlon, DES57, Tom McGrath), 118 guests, and 0 robots.
Topics128,117
Posts1,056,296
Members48,439
#753454 06/10/2011 2:49 AM
Can I use the same tach dwell meter on a 6-volt as well as a 12-volt vehicle? Mine does not have a voltage selector, so I'm a little hesitant to try it on a 6-volt system.
Some work OK, others don't. You won't hurt anything by trying, since the internal resistance of the meter will prevent any overload on 6 volts. The readings might not be accurate, though.
i have a modern sears/craftsman analyzer. i have ony been able to use it for rpms. when dwell is selected, i get nothing that makes sense so i stopped trying to use it. i just set points with a feeler gage. some have told me that it can be done but no one has shown me how.
It's possible to use an old-fashioned analog voltmeter (the one with the needle, not digital) as a dwell meter. When the points are open, the meter will read applied voltage, the same as is coming to the coil. "Points closed" will read zero volts, or a tiny fraction of a volt if the points are a little dirty. It's pretty simple to figure out the voltage that will be indicated for a particular percentage of "points closed" time, and convert that to a "degrees of dwell" reading. Since most distributors work best at about a 66% "points closed" time, adjust the point gap to read about 1/3 of applied voltage to the coil with the engine idling.
since i dont have an analog meter i was wondering if my analog analyzer set on the volt function would work the same as a analog volt meter would? ohwell
It probably would work that way. If the points are set right, there should be about 1/3 of the applied voltage to the coil at the distributor primary terminal with the engine running at idle.
There is a simple way to get the 12 volt meter to work on the 6 volt ignition system. It requires a battery from a motorcycle, dry cell from a light, whatever has 12 volts.
Connect the power wires from the tach/dwell to the 12 volt battery, then, add a ground wire from the 12 volt battery to the engine, and connect the sensor wire form the meter to the negative post on the coil. read dwell/rpms, set accordingly.
The power supply from the 12 volt battery will NOT interface/interfere with the 6 volt system. The ground wire from the 12 volt battery to the engine proper only completes the READ circuit on the meter, the two different voltage systems remain separated.
Dwell meter/tach reads correctly when connected in this method.
CONFIRMED, thanks.
