| | | Forums66 Topics128,036 Posts1,055,450 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2009 Posts: 54 | Have 6-volt system very unreliable with starting ,any suggestions? | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | number of possibilities: most likely 2= undersize battery cables, like the common ones for 12V instead of proper heavy 6V ones, and poor grounds - might also be a weak cell in the battery - or it needs a tuneup - carb iffy
Bill | | | | | Joined: Oct 2009 Posts: 37 New Guy | | New Guy Joined: Oct 2009 Posts: 37 | Ever considered installing a 8 Volt battery? Your generator will charge it if you adjust the regulator.. it does mess up the gages tho unless you use a voltage reducer for the dash.
I got by this way for several years before converting the truck to 12 V
good luck | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Ever considered installing a 8 Volt battery? Your generator will charge it if you adjust the regulator.. it does mess up the gages tho unless you use a voltage reducer for the dash.
good luck You got by with a bandaid fix for several years. With proper grounds and the right size cables there's no need for an 8 volt "fix". | | | | | Joined: Feb 2004 Posts: 29,751 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,751 | An 8 volt battery is a solution to a nonexistent problem. The only time I've ever seen one used effectively was on the family race car, a 1934 Ford coupe in the mid-1950's, and we didn't run a charging system! Jerry
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | In no particular order of importance because they are all important: Proper size battery cables - absolute minimum size 1 gauge, 0 or 00 would be better; clean battery cable contacts, both ends, both cables; good high amp battery, a 400 amp tractor battery is marginal at best (I use Optima 800 amp); sound starter with a clean ground to the block. All that is if "hard to start" means is cranks slow. If it cranks OK but fails to fire that's a different issue.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Hard starting on a 6v system is indeed a problem that is often reported. Using an 8v battery sort of hides the problem and is, at best, a temporary solution (which can be tough on 6v light bulbs). As, posted above, the most common cause is incorrect or bad battery cables and/or bad grounds. Here is list of progressively more costly "solutions" that many people have posted over the years. Good luck. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Please tell me what application the 8 volt battery is made for because I have forgotten the answer. | | | | | Joined: Feb 2004 Posts: 29,751 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,751 | The only application I can think of was on some farm tractors from the mid-1940's through the early 50's before everybody went to 12 volts. In a situation where there were virtually no electrical components other than a battery, starter and generator, and the ignition system was usually a magneto, it made a little sense, I guess. The tractor gets started once, works all day, shuts down overnight, and fires up again the next morning. A 3-brush generator trickle-charges the battery during several hours of running, and there's little if any load other than the occasional shutdown and restart. None of that applies to a street-driven vehicle! Jerry
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | It is quite amazing that they still make them. I have seen the odd one at car shows and seeing four caps is always intriguing. | | |
