8 members (Gdads51, 50Chevy3100, Bill Hanlon, Charles in CA, Peggy M, dt235sd, TUTS 59, moparguy),
91
8
Mod | | | Forums66 Topics128,095 Posts1,056,078 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 21 New Guy | | New Guy Joined: Nov 2005 Posts: 21 | Tired of smelling gas fumes from my in-cab tank. Would like to convert filler neck to a non-vented cap with a remote vent tube. I've searched throught 450 posts with plenty of opinions regarding relocating tank altogether; I'm not interested in that as I use the space between the rear frame rails for my spare tire. I'm sure someone has done this before and I need guidance as to engineering and safety. | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | If the filler neck clamps & filler neck rubber hose are properly secured and in good-order, you will not have any fuel fumes in the cab. Have you corrected any issues you may have with these items or checked to see if the tank is leaking anywhere? I have corrected these issues on may factory in-cab fuel tanks over the years and the results were a fume-free cab, without the extra cost of relocating the tank, to the rear frame rails. | | | | | Joined: Nov 2005 Posts: 21 New Guy | | New Guy Joined: Nov 2005 Posts: 21 | Let me clarify. The fumes are not emminating in the cab they are wafting in through my window as they vent throught the filler cap. That is why I want to change to a non-vented cap, but I realize that I then need to vent the tank some other way. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | Ave - you'd have to 'remote' the vent at a level above the top of the tank, which would kinda require making a new hole in the body at that level .... not sure why you'd be smelling fumes from the cap vent, it's only a pin hole and should be drawing air in as fuel level goes down, not 'venting' fumes out - I'd suspect that the rubber vent connection inside the cab is old cracked rubber, or as Tony says, the joints/clamps are loose or you have a pin hole weeping under the tank
Bill | | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | Nothing like the hot Florida Sun to make those gas fumes pure out of the cap. That’s why being a Florida Boy I installed A/C and I roll up the windows on the hot days……
My Fleet: 19411953195919651966 1953 Willy's Pickup John Vegetarian- old Indian word for bad hunter
| | | | | Joined: Nov 2005 Posts: 21 New Guy | | New Guy Joined: Nov 2005 Posts: 21 | Inside the cab all the rubber is new and tight, but I have an old locking gas cap with a not-so-tight fit. I had figured on looping the new vent hose to be higher than the tank, but then exiting through the floor, via a ball-check vent tube. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I have an old locking gas cap with a not-so-tight fit. Replacing the cap with one that seals properly will correct the problem.
Bill Burmeister | | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | "I have an old locking gas cap with a not-so-tight fit"
Seems it would be a whole lot easier to change the gas cap. On real hot days I'll get a slight gas smell outside the cab. Especially if the windows have been up and its been sitting a while in the sun where the cab temp is pushing 130+. But if your getting real strong smells its time to change that cap. A new non-locking cap will run you less than $10 at your local parts store.
| | | | | Joined: Nov 2005 Posts: 21 New Guy | | New Guy Joined: Nov 2005 Posts: 21 | Alright, I'll go with you. I'll change the cap, definately the easiest to do. I'll report back in a couple of weeks. Thanks. | | | | | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | If you have any original rubber (or anything pre-about 1990) in your fuel system, it will be susceptible to Ethanol deterioration. The rubber filler extension and the rubber hose at at the bottom of the tank should be replaced with modern rubber compounds. If you really get hung up on venting, you could rig up a system to vent the tank through the front passenger stake pocket in the bed. | | | | | Joined: Jun 2011 Posts: 8 New Guy | | New Guy Joined: Jun 2011 Posts: 8 | Good call on that. Nothing like the original system. | | |
