7 members (Otto Skorzeny, Tom McGrath, Gdads51, TPR57C, 32Fordpuchoptop, Wickedbass, 1 invisible),
97
Mod | | | Forums66 Topics128,094 Posts1,056,051 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 7 New Guy | | New Guy Joined: Nov 2006 Posts: 7 | Can anyone give me any tips on making a one piece hood for my 53 Chevy pickup? I have heard it is a little tricky not to warp the two pieces when welding them together. Thank you. | | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | It's not that difficult. First make sure your hood is a "good" fit on your truck. Decide if you want the center flat or peaked. The first rule of welding is short stitch welds and space them in groups so that you don't build up to much heat. I think the flat surface is easier than peak. The peak requires adding round or square stock to the seam weld. Practice on something until you feel confident, then go for it. Worst case you might have to come up with another hood!! Note: I did not cut off the center lip, I just welded the top seam solid and tacked underside of the seam togeather. Hope this helps. | | |
