Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (Hanks custodian, Wayne67vert, Chip O, greenie-reddy), 115 guests, and 6 robots.
Topics128,291
Posts1,058,585
Members48,492
U
U Offline
I don't think anyone makes repair panels to repair rear arches on 55 - 59 shape chevy panel truck/burbs.
I was thinking that the front arch is a similar profile ?
Also looked at VW campervan rear arches.
Any suggestions on what others have done.
it's been discussed and cussed a lot here, that area is always rotten - no, there are no patches available and a front fender only gives a small amount requiring much slicing and dicing .... 55-66 stepside rear fenders will give you the main molded part around the wheel well, the rest will need to be hand formed from flat sheet
U
U Offline
Thanks Squeeze.
not much chance of finding them in the Uk.
Appreciate the heads up
Bob
You can have the part between the door and the wheel well done at you local machine shop. The rest is as Bill says. I was lucky since I only had minimal rust.
Cheers Dyna
