| | | Forums66 Topics128,292 Posts1,058,593 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 25 New Guy | | New Guy Joined: Sep 2009 Posts: 25 | I don't think anyone makes repair panels to repair rear arches on 55 - 59 shape chevy panel truck/burbs.
I was thinking that the front arch is a similar profile ? Also looked at VW campervan rear arches.
Any suggestions on what others have done. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | it's been discussed and cussed a lot here, that area is always rotten - no, there are no patches available and a front fender only gives a small amount requiring much slicing and dicing .... 55-66 stepside rear fenders will give you the main molded part around the wheel well, the rest will need to be hand formed from flat sheet
Bill | | | | | Joined: Sep 2009 Posts: 25 New Guy | | New Guy Joined: Sep 2009 Posts: 25 | Thanks Squeeze.
not much chance of finding them in the Uk.
Appreciate the heads up
Bob | | | | | Joined: Jul 2010 Posts: 90 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 90 | You can have the part between the door and the wheel well done at you local machine shop. The rest is as Bill says. I was lucky since I only had minimal rust.
Cheers Dyna | | |
