I finally pulled the 3-speed transmission out of my '49 3100 to see why my speedometer wasn't working. After pulling the rear bearing support to confirm that the gear and spacers were in correctly,I believe I have the wrong front yoke.It only sticks about half way through the rear bearing support and likes about a half inch of contacting the spacer tube to squeeze the speedo gear.If anyone has the correct yoke lying around,could I get a length measurment to confirm this?Any help is appreciated. Chip
