4 members (Shardean, Tstan7, 2 invisible),
94
Mod | | | Forums66 Topics128,022 Posts1,055,353 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | i have added a pi here: http://i185.photobucket.com/albums/x264/uffeg/Viking%20Engine/20110123122.jpgI ordered a carb rebould kit, and it seemed okay, until I took the carb apart. The kit had a round accelerator pump, and mine is flat, and long. The carb tag is long gone, but I have the number 7004510 inside. Guess someone has changed the truck carb for a car one  and that's the reason why I have nothing to connect the hose from the valvecover, in the air filter. So my question, can I use another carb, for the 2 ton 6500 truck ? Like a Holley, or whatever ? Or else I need another carb rebuild kit, that includes the flat rochester B acc pump. Br /Ulf My Chevy Viking 1959Ulf Hedlund. Eskilstuna. Sweden [email protected]Also: Ford Galaxie 4 dr 1959 Ford Custom 4 dr 1964 Ford Mustang GT 2005
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy lastchancetowing, as far as the hose to the air filter is concerned that is the way it is suppossed to be. Your carb has a manual choke, a lot of car carbs have automatic chokes, maybe someone changed up to a newer carb, but it doesn't look too different from what should be there, could you post a picture of the accelerator pump, I have never seen anything other than a round one. | | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | My Chevy Viking 1959Ulf Hedlund. Eskilstuna. Sweden [email protected]Also: Ford Galaxie 4 dr 1959 Ford Custom 4 dr 1964 Ford Mustang GT 2005
| | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | The engine in your truck looks to be a 261 not a 235.A carb from a 40-52 car would be smaller and would not fit the manifold. Maybe you have the wrong kit for the carb, but the round pump should be the right one.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | okay, but the round pump can't fit my carb. So I have the wrong kit yes. But I know also I have the wrong carb, since the air cleaner is wrong too. And the carb looks exactly as an early car model B inside. like this one: http://chevy.oldcarmanualproject.com/booklets/5020mts09.htm My Chevy Viking 1959Ulf Hedlund. Eskilstuna. Sweden [email protected]Also: Ford Galaxie 4 dr 1959 Ford Custom 4 dr 1964 Ford Mustang GT 2005
| | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | Ulf, I've never seen a model B carb that doesn't have a round accelerator pump. I have a 261 in my truck and have a holley/weber carb from Langdons stovebolt engine company. It runs good with that carb.
There is a bolter by the name of carb king, that may be able to help you. The only thing I can think of is maybe the carb is off of a 216 and had a smaller diameter pump.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Ulf - The accelerator pump your photo album looks round to me. Are you talking about another part?
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | looking back at Ulfs first post, I believe he's saying the old acc pump rod is a flat bar, the new one is shorter and round rod .... he's not talking about the piston end being round or flat
Bill | | | | | Joined: Nov 2002 Posts: 2,763 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,763 | One of the many issues we face when selling carburetor kits is the accepted myth "they are all the same" or "one fits all". And then I am the bad guy for not wishing to sell a kit if the customer does not have the original identification number. Ulf is indeed correct that Rochester DID make a flat shaft pump for some of the model B carbs. In fact, they made more than one! They also made more than one with the round shaft. Several in fact. Just to prove the point, I grabbed three different (2 round shaft and one flat shaft) for the picture below. http://www.thecarburetorshop.com/Rochester_B_pumps.jpgThere are also a number of DIFFERENT airhorn gaskets, and throttle body gaskets; which are NOT necessarily interchangeable. Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | The carb pictures appears to be a late model "B". It has the "high top" on it which was a later design. The carb looks like the one I have on my '53 6400. I havn't researched the carb numbers but believe that a 235 carb would fit a 261. Don | | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | So if I get another well running carb from a 1955 car with a 235 in, can it be a good enough fit ?
Don't want to buy something completely wrong.
CARBKING, do you think it's the original carb, only my air cleaner that is wrong then... since it's without the mounting for the hose from valve cover My Chevy Viking 1959Ulf Hedlund. Eskilstuna. Sweden [email protected]Also: Ford Galaxie 4 dr 1959 Ford Custom 4 dr 1964 Ford Mustang GT 2005
| | | | | Joined: Nov 2002 Posts: 2,763 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,763 | CARBKING, do you think it's the original carb, only my air cleaner that is wrong then... since it's without the mounting for the hose from valve cover Don't know. We won't work on the B (for about the last 15 years), so cannot say from first hand experience. Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | |
