4 members (DoubleB, greenie-reddy, 41appletruck, Oswald), 85 guests, and 1 robot.
Topics128,091
Posts1,056,038
Members48,433
#752858 06/07/2011 11:04 PM
I've been curious about this for a while. What was the reason car makers used torque tubes? It makes sense to me why Ford used them with transverse springs, or Buick with coil springs. But why use a torqe tube with a leaf spring set-up like Chevy? It couldn't have been cheaper than an open drive shaft? Was it originally seen as smoother? mavbe allowed softer springs? Or less stress on the drive train? Just wondering what was the reason.
Thank you for the links - that helps explain it. It was one of those things I thought there should be a reason, but I was clueless. Thanks!
Socket Breaker
Socket Breaker
Good info. as usual tc... I had read one of them before.
A good reminder.
-W
For anyone who has never seen nor heard of a torque-tube enclosed drive-shaft, Dave's question is one of the first for a person looking at at pre-55 1/2 ton (and other) Chevrolet truck.
http://en.wikipedia.org/wiki/Torque_tube
"The torque tube driveline is also used in Sprintcars and Midget cars. The C5 and C6 Chevrolet Corvette, Lexus LF-A, Porsche 924, Porsche 928, Porsche 944, Aston Martin DBR9, Aston Martin DBS, Aston Martin DB7, and the Mercedes AMG SLS also use variations on this design, mostly with rear-mounted transaxles."
Used on a modern Mercedes
Used on mid-50s Ramblers
I guess our 1/2 ton torque tubes are live axles with no pan hard link?
Why would my 49 1 ton not employ this?
I would imagine it's something to do with the overall length.
A longer shaft can produce more deflection/oscillation.
More pix on Flickr.
Changing a clutch: A simple drive shaft is out of the way in 5 minutes. A torque tube? On my Porsche it meant dropping the whole transaxle. I seem to recall working on a '47 Chevy pasenger car back in high school and struggling with the torque tube in order to change a clutch. It may be better technology than an open drive shaft, but but not fun to work around.
