8 members (delky, val, UtahYork, Otto Skorzeny, mason86, Bill Hanlon, Woodcmiami, 1 invisible),
60
Mod | | | Forums66 Topics128,030 Posts1,055,424 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#75262 03/22/2007 4:44 PM | Joined: Jul 2004 Posts: 8 Junior Member | | Junior Member Joined: Jul 2004 Posts: 8 | I have a 52 chev truck that has a 235, floor shift and open drive axle. I believe the engine is a 56 year. the tranny has the linkage to adapt to floor, and it jams in between gears sometimes and I have to crawl under and free up. Is it a linkage problem or transmission problem anybody know? It's a 3 speed and 1st and reverse are reversed on the H-shift pattern. | | |
#75263 03/22/2007 4:52 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | nevsquare52,
This type of problem is common to conversion kits. Make sure the shift arms are tight on the shafts coming out of the sidecover. The neutral gate between 1st/reverse and 2nd/hi must be adjusted perfectly. The shift rods should have threaded adjustments. All adjustments are made too the detents in the side cover..these must be firm.
Stuart | | |
