0 members (), 90 guests, and 1 robot.
Topics128,127
Posts1,056,680
Members48,452
#75251 03/22/2007 3:31 PM
Junior Member
Junior Member
Can anyone tell me what this hole in my old carburetor is for?
[img]http://home.mchsi.com/~ohutchinson/carb-hole.jpg[/img]
-Owen
#75252 03/22/2007 9:38 PM
Riding in the Passing Lane
It,s a vent hole. It must be a realy old carb.
1972 Chevy c10 Cheyenne Super
#75253 03/22/2007 11:01 PM
Junior Member
Junior Member
Thanks Wrenchbender. Will it affect the operation of the carb? in other words should I plug it?
-Owen
#75254 03/22/2007 11:10 PM
Hey wrenchbender,what does it vent ?
1951 3100 Chevrolet
#75255 03/22/2007 11:35 PM
It vents the bowl of the carburetor...the guts of the carburetor. I've never seen one like that! Does it have the angled brass tube in the throat too.
Stuart
#75256 03/23/2007 6:57 PM
Junior Member
Junior Member
Yeah, it has the brass tube. other than the vent hole it is pretty similar to my other Rochester, with the exception of a passage from the accelerator plunger tube into the main bowl that is regulated by a small ball bearing on one side and covered with a fine screen on the bowl side.
-Owen
#75257 03/23/2007 7:22 PM
Kermit54,
I'm not the King-O-Carbs, but it sounds like that hole is something special, not just a vent.
Stuart
#75258 03/25/2007 4:08 PM
It was probably the result of a "home brewed" fix, to vent the float chamber. I'd say plug it up, all it will do is make a spot to spill gasoline on the manifold making a fire hazard. As long as the brass tube is clear that's all the vent you need.
#75259 03/26/2007 12:07 AM
CarbKing where are you?
#75260 03/26/2007 12:18 AM
I don't know what it is, but it doesn't look 'home brewed'...it has a nice cast margin around it and almost looks like it has a inner liner...not just a hole through the thin wall.
Stuart
#75261 03/26/2007 3:14 AM
Junior Member
Junior Member
Its clearly part of the original casting. I can't tell if it ever had anything in it (no visible signs). I just don't understand why you would need another vent hole in addition to the brass tube vent.
-Owen
