8 members (Gdads51, frogfarmer, Bill Hanlon, LAROKE, gswbbc, Forty9, 48jim1ton, Hotrod Lincoln),
107
0
Mod | | | Forums66 Topics128,043 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2004 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2004 Posts: 72 | Anyone here ever install a mid sixties three speed with OD in a 59 behind a 235? I am going to do this and wonder what any experiences have been. Thanks!!
52 GMC Suburban...52 Chevy 3/4 ton...49 CHevy 1/2 ton Rod...49 GMC 1/2 ton retro rod project
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I have one behind a 248 in my burb. I love it. Just got back from a 2427 mile trip. Ran 70-75 every chance I got. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I have one behind a 248 in my burb. I love it. Just got back from a 2427 mile trip. Ran 70-75 every chance I got. Got one in mine as well, probably the best alteration I did besides maybe the radial tires. The trans itself will bolt right up. The only issue I can think of might be the driveshaft, depending on which main transmission and overdrive unit it is. I beleive the later trans (7 bolt cover) is longer than the early trans, there may also be a length differenc from the RH10 (early) and RH12 (late) overdrive units. You may need a shorter driveshaft.
Bill Burmeister | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | We installed the Saganaw 3 sp OD in a 56 3100. No change to the driveshaft length. You will need a fine spline front yoke and make modifications to the shift arms and rods. The early version (55-65) will bolt right in - no mods. Fred
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | If you die the day after you do this swap there isn't a mortician in the world that would be able to get the smile off your face.
Evan
| | | | | Joined: Oct 2004 Posts: 348 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 348 | thats a good swap but i like the t-5 better | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | I have t-5 in my 54 and have put more than 10,000 miles on it, and love it, 2000 of that in the last month. also i got 18.5 mpg in town and improved 4 lane roads.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The T5 is a good choice, but the SM318 is not only a direct bolt in, but retains the stock shift linkage, no need to cut a hole in the floor for a shifter. It also has the advantage of an automatic kickdown for passing.
