0 members (),
206
Mod | | | Forums66 Topics128,089 Posts1,056,441 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2004 Posts: 438 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 438 | Hi, I am trying to find valve cover gaskets and possibly steel covers for 1955 Power Pack heads. The bolt holes are offset/staggered.
I can find a couple of cork versions, but I would really prefer nice ones with steel inserts and rubber/poly... whatever. :-)
I've spent hours googling, and my eyes are crossed. ugh.... Anybody know where I might find some?
| | | | | Joined: Nov 2009 Posts: 220 Shop Shark | | Shop Shark Joined: Nov 2009 Posts: 220 | Husker -
I just found you yesterday (the hard way) about the staggered valve cover bolt holes. I picked up a set of chrome valve covers at a swap meet, cleaned them up, and they didn't fit for just that reason.
As far as valve covers themselves go, I think you'll be stuck using original steel ones.
I got my gaskets at Napa...I just asked for gaskets for a 1975 350. The ones they gave me were some kind of black stiff rubber, and they were set up to fit either the early offset holes or the straight holes. I think they were $10, Fel-Pro.
Chris | | | | | Joined: Feb 2004 Posts: 29,829 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,829 | The offset-hole heads were used from 55 through 59, and there were some aftermarket cast aluminum covers made by various manufacturers such as Offenhauser, etc. There are also some very pricey original-equipment Corvette script cast aluminum covers still around. It used to be hard to give away a set of offset-hole covers - - - -now they're a hot item for original-condition restorers! Jerry
| | | | | Joined: Apr 2004 Posts: 438 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 438 | Thanks, Chris and Jerry. I found probably the same Fel-Pro black rubber gasket at www.rockauto.com that you got at Napa, Chris. Hope it works well. And I did find a set a triple-dipped chrome covers off ebay. They have the breather ports, so I'll be good to go with those. :-) Jerry, actually what I am taking off is a set of the cast aluminum "corvette" covers. Maybe I'll stick them in the swap meet section when I'm done changing them out. Thanks! | | | | | Joined: Feb 2004 Posts: 29,829 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,829 | You'll probably get a better response by putting them on Epay- - - -a bunch of old truck restorers won't have much use for them, as they only fit original-equipment V-8 heads from passenger car engines from over 50 years ago, and they would only be of any real use to someone who is restoring a Corvette with a period-correct engine. To the right collector, they would be worth some big dollars, though. Jerry
