7 members (NJC, David Bush, Oswald, Otto Skorzeny, GRNHydra, 2-Ton, Rusted Nut),
76
Mod | | | Forums66 Topics128,060 Posts1,055,838 Members48,427 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Hi all - Will you please give me some pointers about tube bending re: tools, line stock, and tips? I'm gonna try to bend a pump-to-carb fuel line for my '54 3100 235 with Rochester B carb, "angled port" glass bowl fuel pump, and Durex-Moraine glass bowl fuel filter. 1/4"ID; 5/16"OD steel line (not stainless). Never done it before / not afraid to try. My goal is to make the line look factory original. I bought pre-bent lines from two suppliers - - neither of them fit correctly. > TOOLS: Which, if any, of these HF bending tools would be an acceptable choice? Any better choices for the money from other suppliers? I will probably use the tool only once ... or a few times if I screw up. "Tube Bending Pliers""1/8" to 1/4" Tube Bender""Tubing Bender"> LINE STOCK: Where can I buy steel line locally? Looks like I can use a 3' line with premade flared ends and brass fittings. Advance Auto Parts has only black brake lines. I may cut off one flared end and use a compression fitting to connect to the Durex fuel filter - as shown in the 1954 Accessories Installation Manual. > TIPS? Thanks as always for your help,
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I use one like #3. It makes a good bend but you cant get real close to the fitting. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: May 2005 Posts: 487 'Bolter | | 'Bolter Joined: May 2005 Posts: 487 | I've got a set of the pliers. They worked well for making really tight bends close to the fitting. BUT, they left tool marks on the tubing that I wouldn't want on the fuel line where it'd be highly visible. see what I mean I usually use a KD Tools 2189 for more gentle bends. I expect the HF 3755 will work fine as well regards, Leon | | | | | Joined: Mar 2010 Posts: 843 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 843 | Lonnie, I used a $10 tubing bender from Summit racing. It's a simple device and makes tight bends in 1/4", 5/16" and 3/8" tubing and can get the bends very close to the fitting. If you'd like to see pictures of how tight the bends can be made, I'd be glad to email you a couple. I've use it for gasoline, brake and transmission cooler hard lines. I don't know how to post pictures here (no computer skills). My email is [email protected]
Ray
| | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | I know this is a dumb question - what friendly local auto parts store sells steel lines with flares and fittings on each end? Is a bender like Ray bought from Summit available at my FLAPS? (Ray - is this the bender that you bought?) Otherwise, I'll buy from HF. My truck has been down since early April waiting on a fuel line. Want to bend now!
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Feb 2000 Posts: 5,205 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,205 | NAPA will have the brake line in multiple lengths. Get a little longer then needed, the bends will use up some length. Get the bottom tool in your list, it will do everything you need for a one time use tool. I would stay away from compression fittings on fuel lines, I know a lot of guys do it and get leak free results, but NHRA and other racing associations ban them. I figure if they don't want them, neither do I.
NAPA also sells a greenish/gray line that can be bent with your hands. Its pretty fool proof and kink free. If you can stand the color, its a good way to go.
When you go buy some line, buy a extra piece for practice. It takes a time or two to figure out where to start the bend so it ends at the right distance from where you started. You will also note that the line has a weld seem on it, use that as a reference guide so you know which way the bends should be going from one another.
Start at the carburetor and work down toward the fuel pump. If you have extra line or miss the turn a little, you can correct it and have it not show to much. A mistake at the carb will be obvious since its the first thing you see.
Joe | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Lots of good info on this thread. I gotta question - is copper tubing o.k. to use on fuel lines? I see Grandpa used it on his truck but I'm just wondering why all the factory lines are steel and not copper? | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Lots of good info on this thread. I gotta question - is copper tubing o.k. to use on fuel lines? I see Grandpa used it on his truck but I'm just wondering why all the factory lines are steel and not copper? It's been done, and was used factory in the teens and 20's. Now days we're concerned with vibration and the copper work hardening, getting brittle, and finally cracking. Steel line is the better answer. Copper-nickel alloy brake and fuel line is also a great, and I think an even better choice. Grigg | | | | | Joined: Mar 2010 Posts: 843 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 843 | Lonnie, that's a much nicer bender than the one I got from Summit years ago. You can get tubes with nuts installed and double flared ends in a variety of lengths from auto parts stores.
When I'm making a complicated hard line I make it first as a pattern using a gas welding rod. Then I duplicate the pattern with tubing. Mark on the tubing where the CENTER of the bend will be then place that mark on the center of the bender mandrel.
It's very cool that you are willing to try this. You can do it! It's really sad how many guys want to get somebody else to do all of these interesting tasks. We're never too old to learn! I'm 66 and I recently re-learned tig welding after not touching it for over 40 years. Yee haw!!!
Ray
| | | | | Joined: Dec 2010 Posts: 291 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 291 | I only used copper cause I like the look it gives. For me it is a classic look but its up to you. Steel will last longer for sure. But do what you like. Good luck. Easy job to do once you got all the right tools. | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | buy two lines that way when you mess one up you dont have to run back to get another one only to find out they are closed. what i do is to tape the nuts to the end of the tube. too many times ive bent the tube only to find out in the process that the nut ended up on the wrong side of the bend. i have a shop full of silly straws due to mistakes. | | | | | Joined: Jul 2010 Posts: 16 New Guy | | New Guy Joined: Jul 2010 Posts: 16 | Is that a fuel filter between the line and carburetor? | | | | | Joined: Mar 2008 Posts: 374 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 374 | "what i do is to tape the nuts to the end of the tube".
AMEN! | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I have bent lines around bottles before.
However. Today, I think I would use one of the tools.
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Thanks to all of you, I bent my fuel line - and it looks pretty good! Driver's side w/Durex fuel filter. Passenger's side. Difficult to see where the line bends to go down. I kicked it out a little to give some more distance from the heater and radiator hoses. The vac advance line is from InLine Tube via Chev's of the 40's. I am returning the pump to carb fuel line that I bought because it wasn't bent correctly. That's why I started this thread asking for advice. Line clips from Shafer's Classic Reproductions, Tampa - via Eckler's. I bought the HF #3755 tube bender and #66534 double flare tool. About $20 for both with coupons. Took three pieces of 40" NAPA tube stock to get it right - steel colored, not green. "Grandpas Truck" thanks for the videos. Joe - You convinced me. I used flared fittings at all unions. And thanks for suggesting that I start at the carb. For some reason, I had planned to start at the pump. No fuel in the filter because I haven't started it yet ... The carb did not have an insulator, so I added one. Looks like a previous owner cut off the tip of the throttle carb rod and welded on a threaded piece to compensate for the lower height of the carb without the insulator. So now, the rod is too short. Can't start it until I fix it. Guess I'll have longer threaded rod welded to it. Eventually try to find the correct rod.Thanks again for your guidance.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Apr 2010 Posts: 283 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 283 | For an inexpensive chrome plated line in 3/8 I used to buy the plated copper lines that were available for plumbing installation.It worked just like bare copper and seemed to be high quality chrome.Probably been replaced by plastic now like everything else.
Bob Taylor
| | | | | Joined: May 2005 Posts: 487 'Bolter | | 'Bolter Joined: May 2005 Posts: 487 | Lonnie,
You can make the accelerator rod yourself out of of steel rod stock from Lowes, Home Depot or equivalent. A 1/4 x 3 ft piece is about $2. You did such a good job on the fuel line, it should be a piece of cake.
regards, Leon | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Hi Leon,
Thanks for your confidence in my limited abilities! I made a separate post re: the short carb rod. Doubt that I will try to make a new one.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | I found the source of the threaded carburetor rod on my truck ... Posted in another thread.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Dec 2010 Posts: 291 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 291 | ScottSeWall, Yes that is a filter between the carb and the fuel line. | | |
