0 members (), 126 guests, and 3 robots.
Topics128,113
Posts1,056,619
Members48,450
#751782 06/03/2011 5:17 PM
Does the 216 make enough vacuum to run power brakes? I have discs up front and drums out back. If not, can I run a fuel/vacuum pump to make up for it?? Thanks
3B Offline
Hy Jake T, if your engine is in good condition and tuned properly it should have no problem supplying sufficient vacuum to power your power brakes. High performance engines with radical cams quite often cannot provide sufficient vacuum at idle to operate the power brakes efficiently, hope that helps.
Ok, thanks a lot. It's a stock 216, it's supposed to be rebuilt, so we'll see. Thanks for your help.
