1 members (ShopRag),
169
Mod | | | Forums66 Topics128,271 Posts1,058,314 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2011 Posts: 12 New Guy | | New Guy Joined: Jun 2011 Posts: 12 | well i took off the oil pan to try to free up the crank shaft but it wont come offf all the way becuase the tie rod is in the way so im tryin to take that off but it wont budge anyone have and secrets to share? im new at theis whole restoration thing!!
1950 GMC 1 ton 250 series
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Jack the front of the truck up and the pan should clear the dropped axle. Or, for the tie rod, soak the plugs threads in the end with PB Blast/Kroil/WD40/ATF+Acetone or any of your favorite penetrating oil, pull the cotter pin and use an impact driver with the proper size drag link socket and back out the plug, then you can remove your tie rod from the ball. DG
Denny G Sandwich, IL
| | | | | Joined: Aug 2005 Posts: 6,379 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,379 | On my '38 the easiest thing to do is unbolt one side of the cross member at the back of the engine & swing it away.
