| | | Forums66 Topics128,196 Posts1,057,391 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 222 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 222 | dumb question warning! does this type of light on top of the front fenders have a particular name? do these ones look original, and where do I look for replacement plastic covers (cracked) and bulbs (burnt out)? | | | | | Joined: Sep 2010 Posts: 222 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 222 | they're Acrystat lights by Signal Stat, it appears | | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | I don't know for a fact but my guess is they were put on as turn signals. You should be able to get bulbs anywhere. If there are currently bulbs in the sockets pull one a take the number off of the base. If there are no bulbs in the sockets look to see if the pins are straight across or offset and if it's a single or double contact.
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | GM and other companies sold accessory directional signals with different styles of fender mounted lamps that look like yours. Some had a lens on one side and some had lenses on two sides.
When I went junk-yarding in VA in the 60s and 70s, a majority of the trucks in the junk yards had similar directional lamps mounted on the fenders.
6v and 12v replacement bulbs should be readily available at a good parts store. As Tiny suggests, take out a bulb and take it to a NAPA or other parts store.
| | | | | Joined: Sep 2010 Posts: 222 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 222 | | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | | | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | That number doesn't ring a bell at all. It should have a two or four digit number like 89 or 1157. If you can't find a number take it with you to the parts house like Tim said.
| | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | As for replacement lenses, I have not seen any repros. Your best bet would be swap meet or you might get lucky on EBay...I see quite a few complete lamps on there. Possibly a late model replacement lens would fit your housing??? Try NAPA/ O'Reilly etc. Good luck!
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | | | | Joined: Sep 2010 Posts: 222 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 222 | I called Truck-Lite (who purchased Signal Stat) and they turned me on to the replacement lights, which are Signal Stat 9015 (red) and 9015W (white). Just posting here in case anyone else has the same replacement lens problem with these lollipop lights. | | |
