5 members (Bill Hanlon, 68ironhead, 48jim1ton, Hotrod Lincoln, Otto Skorzeny), 121 guests, and 2 robots.
Topics128,032
Posts1,055,517
Members48,425
#751088 06/01/2011 3:00 AM
Anyone here ever install a mid sixties three speed with OD in a 59 behind a 235? I am going to do this and wonder what any experiences have been. Thanks!!
52 GMC Suburban...52 Chevy 3/4 ton...49 CHevy 1/2 ton Rod...49 GMC 1/2 ton retro rod project
I have one behind a 248 in my burb. I love it. Just got back from a 2427 mile trip. Ran 70-75 every chance I got.
Cletis #751116 06/01/2011 3:44 AM
Got one in mine as well, probably the best alteration I did besides maybe the radial tires.
The trans itself will bolt right up. The only issue I can think of might be the driveshaft, depending on which main transmission and overdrive unit it is. I beleive the later trans (7 bolt cover) is longer than the early trans, there may also be a length differenc from the RH10 (early) and RH12 (late) overdrive units. You may need a shorter driveshaft.
Bill Burmeister
We installed the Saganaw 3 sp OD in a 56 3100. No change to the driveshaft length. You will need a fine spline front yoke and make modifications to the shift arms and rods. The early version (55-65) will bolt right in - no mods.
Fred
rfs56trk #752124 06/05/2011 4:31 AM
If you die the day after you do this swap there isn't a mortician in the world that would be able to get the smile off your face.
Evan
coilover #752257 06/05/2011 9:49 PM
thats a good swap but i like the t-5 better
1949 SUBURBAN
I have t-5 in my 54 and have put more than 10,000 miles on it, and love it, 2000 of that in the last month. also i got 18.5 mpg in town and improved 4 lane roads.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
WE b OLD #752310 06/06/2011 12:53 AM
The T5 is a good choice, but the SM318 is not only a direct bolt in, but retains the stock shift linkage, no need to cut a hole in the floor for a shifter. It also has the advantage of an automatic kickdown for passing.
Bill Burmeister
