Brrrr
place holder
6 members (DoubleB, Shade Baby, Lightholder's Dad, Oswald, Sjm, Phak1), 158 guests, and 4 robots.
Topics128,271
Posts1,058,417
Members48,485
#751057 06/01/2011 1:57 AM
RAK
Offline
Now that I'm spending time in Oregon I need the heater to work better. It blows OK but not too hot what should I be checking? I think the heater core is new? Thanks
k10 Offline
First question is this- Do you know how to use it?
Second question is, how many levers does it have? 2 or 4?
A decent 4 lever heater (deluxe) or a 2 lever(recirculating) should blast you right out of there on a cold day. But if the levers aren't in the right positions, then you're just movin' air. Here's another spot where an owner's manual would have you way ahead of the game.
RAK
Offline
4 levers- Heat/air/fan/defrost.I have an owner's manual. Now what?
check your antifreeze for starters. If its old you wont get heat
Have you felt the heater hoses to see if they are hot? That will tell you real quick if you are getting flow to the heater.
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
RAK
Offline
Good ideas! I do have heat flow it's just not hot.I'll check both items.Thanks
