7 members (Forty9, fonz8261, jkreiner, treegrower, Bill Hanlon, Wally / Montana, TexasJim50),
51
0
Mod | | | Forums66 Topics128,074 Posts1,055,914 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 25 New Guy | | New Guy Joined: Sep 2010 Posts: 25 | Does the 216 need the valves adjusted periodically or only if its rebuilt? I've got a buddy that knows how to do it, I'm closing in on getting it on the road.
Keep movin' forward.
| | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | The valves need to adjusted periodically , I did mine when I was doing a tune up ,points,plugs,timming,adjust valves.
Pete | | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | A daily driver will need an ignition tune-up and a valve adjustment about twice a year. A trailer queen can get by with a once-annual servicing, or less. Jerry
| | | | | Joined: Sep 2010 Posts: 25 New Guy | | New Guy Joined: Sep 2010 Posts: 25 | Thank you for the info. Once Rick shows me how to do it, I'll take it from there.I'll be happy to get it on the road. Jon
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Take the "Tech Tips" link at the top of the page and scroll down to Engine/Valve Adjustment.
| | | | | Joined: Sep 2010 Posts: 25 New Guy | | New Guy Joined: Sep 2010 Posts: 25 | Thank you. The Tech tip spells it out perfect,but I never adjusted valves before so I don't know what I'm looking at as far as how and where to measure the tolerances.My master mechanic buddy will show me what to get for feeler gauges - and how to measure the valves. The tech tip will show him the seguence and tolerances. Thanks again ! I put together all new brakes - master and wheel cylinders and lines, new water pump, fuel filter . I'll have Rick check my work and work together on the valves and whatever else he sees and/or hears. Thanks for pointing me in the right direction. Thanks Pete, HL, and Tiny
