0 members (), 102 guests, and 3 robots.
Topics128,186
Posts1,057,319
Members48,469
#75097 03/20/2007 1:47 AM
Is there a direct bolt in dual master cylinder to convert my 55 1st series? Using the later model dual chamber master cylinder with an adapter won't work because of space limitations (that big old 400 lb Hydra-Matic takes up a bunch of room).
cgresham1212
If you don't drive it, why have it?
55 1st Series 3100 5 window
#75098 03/20/2007 3:13 AM
3B Offline
Hy cgresham1212, If you have enough room you may be able to mount the master farther towards the rear of the truck and make a mount and linkage for it, hope that helps.
#75099 03/20/2007 11:02 PM
Cgresham1212 TCI sells a dual MC with a small booster that might work for you.
~Jim
#75100 03/21/2007 4:11 AM
Cgresham1212,
You did not state if you want to use a manual or power master cylinder. I have a 54 with a hydo in it and I made my own bracket. The trans side of the bracket detaches so that the trans side pan can be removed. If you have any fabrication skills or know a fabricator, this is an easy bracket to fab. Check out my build pictures for some pictures of the master cylinder and mount.
