3 members (classicfins, Donf, 1 invisible),
72
0
Mod | | | Forums66 Topics128,108 Posts1,056,568 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 170 Shop Shark | | Shop Shark Joined: Feb 2011 Posts: 170 | I have a new set of Hastings rings and there are two different comp. rings. One has a bevel on the inside top and one is square, there is no instruction as to which ring goes in which groove. I think the beveled one goes in the second groove but am not sure does anyone know for sure? The box usually identifies this but not this one. Thanks, Scott | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 |
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | That link doesn't seem to answer your question. If you don't get an answer tonight, I will dig in to my spare set of rings to see if I can help. They usually have some type of cutaway on the inner top of the top ring to cause the ring to seal better under extreme pressure. | | | | | Joined: Feb 2011 Posts: 170 Shop Shark | | Shop Shark Joined: Feb 2011 Posts: 170 | Thanks, I did look at that already. The Hastings ring with the bevel on the inside is marked with a dot to indicate up. The square ring is not marked and can go either way. This much the instruction sheet does tell me, what I don't know is which one goes in which groove. Thanks Scott | | | | | Joined: Jun 2008 Posts: 325 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 325 | Hi Willy.
I put McHenry's piston rings into my '52 216. The beveled ring went into the upper groove with the bevel facing up. The square ring went into the second or middle groove.
McHenry's second ring was not entirely square. It had a very small notch taken from the bottom of the ring that faced downwards. Maybe have a close look at your rings to see if your square rings are truly square, or if they are notched. | | | | | Joined: Feb 2004 Posts: 29,835 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,835 | Rings with a dot or a "T" on them are installed with the marking toward the top of the piston. Rings with any sort of bevel, chamfer, or other shape on the inside of the ring are "scraper" rings with a dual purpose. They seal compression on the upstroke, and scrape nany oil that gets past the oil ring back toward the crankcase on the sownstroke. Always install those rings in the second groove, with the chamfer or bevel pointing up. Jerry
| | | | | Joined: Feb 2011 Posts: 170 Shop Shark | | Shop Shark Joined: Feb 2011 Posts: 170 | I tend to agree with Hotrod Lincoln but have also had opposing opinions, so I better wait and call Hastings tomorrow. Thanks for all the input, I'll let you all know what I find out. Scott | | | | | Joined: Apr 2011 Posts: 57 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 57 | That second ring is not square, it has a scraper edge. The Hastings link will resolve 'for sure'.{Instructions for ring installation are placed inside the box}
www.hastingsmfg.com/.../compression_​ring_installation.htm
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I checked my spare rings and they are Perfect Circle. They has a notch sround the inside of the top ring and a notch arouns the outside of the second ring. | | | | | Joined: Feb 2011 Posts: 170 Shop Shark | | Shop Shark Joined: Feb 2011 Posts: 170 | Yes the top ring is plain and the second with the bevel is a scraper to aid the oil control ring. Thanks again, Scott | | |
