6 members (TexasJim50, stlcardinalsguy, Woodcmiami, klhansen, Hanks custodian, Wally / Montana), 64 guests, and 2 robots.
Topics128,059
Posts1,055,820
#750770 05/31/2011 1:26 AM
Does the 216 need the valves adjusted periodically or only if its rebuilt? I've got a buddy that knows how to do it, I'm closing in on getting it on the road.
Keep movin' forward.
The valves need to adjusted periodically , I did mine when I was doing a tune up ,points,plugs,timming,adjust valves.
Pete
A daily driver will need an ignition tune-up and a valve adjustment about twice a year. A trailer queen can get by with a once-annual servicing, or less.
Thank you for the info. Once Rick shows me how to do it, I'll take it from there.I'll be happy to get it on the road. Jon
Ex Hall Monitor
Ex Hall Monitor
Take the "Tech Tips" link at the top of the page and scroll down to Engine/Valve Adjustment.
Thank you. The Tech tip spells it out perfect,but I never adjusted valves before so I don't know what I'm looking at as far as how and where to measure the tolerances.My master mechanic buddy will show me what to get for feeler gauges - and how to measure the valves. The tech tip will show him the seguence and tolerances. Thanks again ! I put together all new brakes - master and wheel cylinders and lines, new water pump, fuel filter . I'll have Rick check my work and work together on the valves and whatever else he sees and/or hears. Thanks for pointing me in the right direction. Thanks Pete, HL, and Tiny
