4 members (55shaker, Southerntruck, Bill Hanlon, FAST55), 75 guests, and 4 robots.
Topics128,056
Posts1,055,803
#750681 05/30/2011 6:03 PM
1954-Chevy, 6400, I wanted to bleed my brakes but I may have a problem. I have the shop manual for my truck but I am confused about the bleeder valve at the wheel. The manual talks about a valve (screw) all I can see is a hex nut that seems to be hollow. Is the screw missing or do I try to unscrew the small hex nut? How do I attatch a hose to the valve for the bleeding process? At this moment I am not worried about the hydrovac unit, which I am currently bypassing. Thanks for any advice.
Pappy
All the same: the bleeder screw, the hex nut thing with the hole in, the bleeder valve..
Usually they have a little nipple on them and you slip a rubber hose over it if you want to.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Grigg #750689 05/30/2011 6:30 PM
Only one of the hex nuts has a nipple end on it. Do I just loosen the nut to bleed the brakes?
Correct, just loosen and bleed as usual.
Or you could install new bleeder screws with the nipple on the end if you are concerned about your paint or making a mess.
I find it's nice to use a hose and submerge the end in a bottle so you can see bubbles or not as you bleed, and with the end submerged you have a little more leeway on closing the screw because if you're slow or late it can't suck much air if the tube is already submerged in brake fluid.
Grigg
---All pictures---
