1 members (Erniegp),
47
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 30 New Guy | | New Guy Joined: Nov 2009 Posts: 30 | 1954-Chevy, 6400, I wanted to bleed my brakes but I may have a problem. I have the shop manual for my truck but I am confused about the bleeder valve at the wheel. The manual talks about a valve (screw) all I can see is a hex nut that seems to be hollow. Is the screw missing or do I try to unscrew the small hex nut? How do I attatch a hose to the valve for the bleeding process? At this moment I am not worried about the hydrovac unit, which I am currently bypassing. Thanks for any advice.
Pappy | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | All the same: the bleeder screw, the hex nut thing with the hole in, the bleeder valve..
Usually they have a little nipple on them and you slip a rubber hose over it if you want to.
Grigg | | | | | Joined: Nov 2009 Posts: 30 New Guy | | New Guy Joined: Nov 2009 Posts: 30 | Only one of the hex nuts has a nipple end on it. Do I just loosen the nut to bleed the brakes? | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Correct, just loosen and bleed as usual.
Or you could install new bleeder screws with the nipple on the end if you are concerned about your paint or making a mess. I find it's nice to use a hose and submerge the end in a bottle so you can see bubbles or not as you bleed, and with the end submerged you have a little more leeway on closing the screw because if you're slow or late it can't suck much air if the tube is already submerged in brake fluid.
Grigg | | |
