8 members (Ponchogl, Peggy M, Gray_Ghost, David Bush, TooMany2count, Tronman, JW51, Wayne67vert), 94 guests, and 2 robots.
Topics128,052
Posts1,055,716
#750163 05/28/2011 12:17 AM
Hey all just happened to talk to a guy at a car show (how many stories start like that) who had a 235 rebuilt 8 years ago sitting in his garage.I don't really need another engine yet but this is a good deal if what he says is true. Would sitting around that long cause any concerns with the engine internals? Thanks Murray
First time I saw this truck I said "That's the one!"
1954 Canadian-built Chev Short Box
Hydra1/2ton #750200 05/28/2011 4:15 AM
1 Offline
The thing about buying used or "rebuilt" engines is you never really know. If you have the mind set that all used engines are pretty much rebuildable cores at best you will never be disappointed.
I have done some rebuilds that sat for a considerable time before they ran and they can get some rust in the cylinders. Alot of times it ends up superficial. If you would fire it up and not have disassembled it again you might never have known. You bag em up ya trap what moisture was there. Ya don't do anything and there is moisture in the air and some of the valves are open.
All used engines are "possibly rebuildable cores"
