1 members (Hugh63c10), 88 guests, and 1 robot.
Topics128,130
Posts1,056,720
Members48,454
#75019 03/18/2007 11:37 PM
Junior Member
Junior Member
Hi again! Been awhile. Thanks for all the accurate advice these past 3 or so years! I finished tan 62 in June, drove it the summer, took it to Autorama Houston during Thanksgiving (won 3rd in conservative trucks 57-72!) and now I'm thinking about some mods where I can make them and still be able to go back stock when it suits me. Has anyone put a 700r4 behind a 261 in a lwb truck with torsion bars? I would like to try this, with the shifter through the floor (I'll find a second trans cover, pedal mount, maybe go to a modern master cylinder for my drums) Thanks for your help again, you folks helped me put together a great truck! Bill.
I once put an Olds 350 with automatic in a 62 lwb,worked just fine.But if you want to use a 700r4 with your 261 you will have to get an adapter kit because it will not bolt up.
Floyd
_____________
Floyd
If we choose being kind over being right,we will
be right every time.
Knowledge is a poor substitute for experience.
Remember what is precious to another, may not be to you, but it
is precious nonetheless.
1948 Chevy 2-Ton
The "hump" in the torsion bar crossmember might cause some interference. Not sure about the tranny you speak of, but when I added the O.D. to my stock 4sp, that was an issue. I had to remove it, shave an 1 1/2" off the top in the center, and have it reinforced. A local welder skilled in chassis work did it for $50.00.
1962 Fleetside 4spd 235 w/O.D. posi 3:90
1990 Subaru Legacy Wagon AWD 2.2 5sp
2013 Ram Tradesman C/V
My Webshot Photos]
