1 members (Samantha),
45
Mod | | | Forums66 Topics128,179 Posts1,057,159 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 97 | Just got the wiring transplant done of my 56 3200 235. Worked my way thru one bug after another. Got the lights and new flasher/ turn signal are working. Radio & speakers are good. The head & tale lights are good. The gas guage has no power at the sending unit well actuall about 3 volts. 12 v into the guage and low to none out. I can't see the gas guage needle on either side of guage. I check it before reassembly and worked ok. Is it possible for the needle to be pinched as I did have that with the speedometer needle before testing prior to installing. | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | The sender gets it power from the gas gauge. It is not something one would nornally measure (with a VOM) while troubleshooting. There are other tests or checks for proper function of the gauge and sender. Make sure your gauge case is grounded. Search the forums as there is a ton of data there as this is one of the most common problems discussed in the electrical section.
| | | | | Joined: Aug 2010 Posts: 368 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 368 | TDuffy, I'm also in the process of getting my wiring complete and when I installed my headlight switch and checked the lights and gauges...I noticed I couldn't see the needle of my gas gauge. It is either buried on either side or somehow I didn't put it in correctly ....I'm bummed cause the gauges were a real bee-ouch to put in. No room under dash and lying upside down to see isn't fun.... I'll tackle that after everything else is complete.. Hope everything works out. | | |
