0 members (),
102
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 84 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 84 | I had my valve cover off to fix a clacking rocker and a different one was gushing oil about 2-4 inches in the air (depending on rpm), out of the engine and onto the floor.
I just had the rockers apart last week. I cleaned everything and put it back together exactly as it was.
When I did the initial valve adjustment everything was oiling as expected, even when up to running temp and full pressure
Is this normal?
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Where the oil holes on the rocker arm tubes on the top or one the bottom?
| | | | | Joined: Nov 2009 Posts: 84 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 84 | They are on the bottom. I already went through that issue when half the rockers holes were up and the other half down. It didn't do this the whole time I did the first valve adjustment, but this time it's just one. | | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | Is the rocker arm cracked? | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I see you have a 1960 engine. I'm wondering if you have 1958 or earlier rockers, or at least the one that squirts. Starting in 1959 Chev moved the groove inside each rocker 1/4" off center so it did not line up with the supply hole. If 1950-58 rockers are used on a 1959-62 engine they can squirt, that is where the drilled head bolt comes in to stop this.
See the USA in your vintage Chevrolet! My Blog | | |
