2 members (BC59, Uncles51), 103 guests, and 1 robot.
Topics128,041
Posts1,055,481
Members48,424
#750030 05/27/2011 4:01 AM
I had my valve cover off to fix a clacking rocker and a different one was gushing oil about 2-4 inches in the air (depending on rpm), out of the engine and onto the floor.
I just had the rockers apart last week. I cleaned everything and put it back together exactly as it was.
When I did the initial valve adjustment everything was oiling as expected, even when up to running temp and full pressure
Is this normal?
Lode51 #750033 05/27/2011 4:03 AM
Where the oil holes on the rocker arm tubes on the top or one the bottom?
They are on the bottom. I already went through that issue when half the rockers holes were up and the other half down. It didn't do this the whole time I did the first valve adjustment, but this time it's just one.
Lode51 #750054 05/27/2011 8:59 AM
Is the rocker arm cracked?
Lode51 #750099 05/27/2011 4:51 PM
I see you have a 1960 engine.
I'm wondering if you have 1958 or earlier rockers, or at least the one that squirts.
Starting in 1959 Chev moved the groove inside each rocker 1/4" off center so it did not line up with the supply hole.
If 1950-58 rockers are used on a 1959-62 engine they can squirt, that is where the drilled head bolt comes in to stop this.
My Blog
