| | | Forums66 Topics128,132 Posts1,056,379 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#74991 03/18/2007 10:40 PM | Joined: Mar 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 388 | Hey guys, just installed my disk/drum system on my '48 1/2t chevy. Now I'm trying to install the res. valves the 2# went on just great because the line is 3/16 , but the back line is 1/4" and the res. valve (10#red)does notexcept thatline only 3/16" all of the books I have (CCP,wilwood) say for front disk use a 2#valve with 3/16" line and the rear drums use a 10#valve with 1/4 brakeline.? Im at a stand still. Also if I use a Adj. Proprtion valve do I also use a stock Pro. valve with my dual m/c, or one or the other. Thanx for all your help. I have looked into the old forums but no answer. | | |
#74992 03/19/2007 12:05 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Brakes can be complicated and your proportioning valve question could be real hard to answer without a lot more information.
My suggestion would be to use an adjustable valve and know you're going to spend some time getting it set up right.
As for the tubing size, I don't know what book you are reading but those I've read say it makes almost no difference. I'd go with 3/16" line in this case because its easier to buy more line at the local parts house than get a different size residual valve from a mail order vender.
Another possible solution is to buy an adapter, but that adds some more joint that might cause problems later.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#74993 03/19/2007 12:33 AM | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy bowtiesr4me, I'm afraid I have questions also. First was the master for a disc/disc system or a disc/drum system? If it's for a disc/drum system it should already have a residual pressure valve built in to the rear system. As for the proportioning valve, you could use a stock one, or if you have to have something new you could just put a pressure reducing valve in the rear system, hope that helps. | | |
#74994 03/19/2007 12:45 AM | Joined: Mar 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 388 | I bought the dual m/c in a disk brake kit from CCP and the m/c is a 77 corvette, but also I was reading in an old magazine and it said that GM went to all 3/16" brake line later on to save money. Thanx for all your help!!!!!!11 keep up the good work | | |
#74995 03/19/2007 1:32 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Originally posted by bowtiesr4me: the m/c is a 77 corvette Wouldn't that be a disk/disk master? You are doing disk and drum aren't you? If its disk on both ends you want two 2# residuals, and won't need the 10# at all.
#74996 03/19/2007 3:38 AM | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | I've used the CPP front disc conversion with corvette disc/drum master, 2 & 10 pound residual valves and a Wilwood adjustable prop valve on several vehicles. Never ran into a 1/4" rear line. The little adaptors for the residual valves are only for 3/16th lines. The Wilwood adjustable prop valve goes behind the 10 pound residual valve in the rear circuit. (Master cylinder to residual valve, then adj prop valve.)DO NOT use your stock prop. valve with the adjustable valve. Normally, 2 turns from fully closed on the adjustable prop. valve is a good place to start tuning your rear brake bias. There is some good info at the following sites: http://www.ecihotrodbrakes.com http://www.mpbrakes.com http://classicperform.com Be careful with the little threaded adaptors for the residual valves....they are not just something you can pick up locally. You may have to run some new 3/16 line to the rear. Hope this helps. Dave | | |
#74997 03/20/2007 2:26 AM | Joined: Mar 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 388 | Hey Dave (Fla54Chevy3100)Thanx for the help! It answered all of my questions. Thank's to you other fellows also.I do have to run 3/16 line because my '48 had 1/4" but thats all gone now! Thank You Again, Mike | | |
#74998 03/20/2007 2:35 AM | Joined: Mar 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 388 | Hope this can help other folks doing this kind of work ,sometimes you just cannot find the answer in books or manuals.It's great to have folks like the STOVEBOLT GANG to help out ! | | |
